Internet
rubyj12
Just put in credit + got internet add on but it won't work any1 no what 2 do?!
You need a membership (not just credit) and an internet add-on (if  the membership doesn't include data) for internet access to work.
You also need to configure your internet/APN settings..
Try the online configurator:
http://community.48months.ie/t5/Need-Help/Internet-not-working/m-p/8361#M2747
If that doesn't work and you're on Android then download the Tweakker APN app from the Google Play Store over wifi and run it:
If that doesn't work then you'll have to try configuring them manually:
Internet Settings
Remember to enable data roaming.
