Internet wont work on Galaxy S4
I had an iPhone 4s and now i got a new Galaxy S4 and my internet wont work on it. What setting do i need to make it work? Please help!
See this thread.
I'd imagine that the S3 settings should be close enough for the S4:
http://community.48months.ie/t5/Need-Help/Settings-for-Samsung-S3/m-p/198#U198
Or just try the Tweakker APN app and see if that configures it automatically:
See this thread.
Same problem here btw, did you manage to get it sorted OP? Calls and texts work, I just came from iPhone4 to Galaxy s4 and no data.
Just an update to others, the internet settings for Galaxy S3, link above, worked for me. Thanks
