Internet usage
amyleew1
What happens if I use my 1gb of data? Do I get charged or does it just not work?
If you use your membership data allowance before the membership month is up then you can no longer access the internet unless you buy a data add-on to tide you over until the membership runs its full monthly course and expires. Data access is never charged from your cash credit balance.
Add-ons
