Internet settings for s5 please???
adel1
Try the online configurator.
http://48months.tweakker.com/choose/Samsung
This seems to be the link for your phone:
http://48months.tweakker.com/choose/Samsung/Galaxy%20S5%20G900F
Make sure that data roaming is also enabled.
8 REPLIES 8
hi i have sm g900f and i have problem with the internet. the signal from internet is just H or H+ no 4G how should be is possible to get setting for this thank you
My model is sm-g900h I hdce tried everything possible but ain't getting no text message for the settings , I need help to set up my mobile data ASAP
The online configurator never worked for me either - on several phones. Never sent any message.
Try downloading the Tweakker APN app over WiFi and see if that configures your settings.
Thank you 🙂 it worked
Glad it helped.
That's correct.
48 doesn't provide 4G access yet.
Thak you for help
