Internet not working
eoin_quilter
On my account I have over 1GB of internet allowance left and any time I try use my 3G it hasn't worked in the last week and it is not because of coverage as it has always worked
10 REPLIES 10
Are your internet/APN settings configured correctly?
http://community.48months.ie/t5/The-Knowledgebase/My-Internet-is-not-working/ta-p/45928
eoin_quilter
Thanks but I've already tried that today and followed all the steps but it still won't work
Is data enabled?
Any update @eoin_quilter?
charleville
Your post was blank so it's not clear what your issue is.
If you meant to ask how to configure your internet settings then follow the instructions here:
Did that help at all @charleville?
zoeclaire1995
Hi, my phone data isn't working, it says I have 3G but it's not working. My membership was only renewed last week and I still have data left! I have tried all the above suggestions
If you followed these instructions
and your configuration settings are definitely correct but data is still not working for you then you need to contact 48 support for more advice/assistance.
