Internet not working
Hi I entered the correct settings on my phone, as instructed on the forum, but my internet connection does not work at all, it's showing as offline whenever i log on to chrome on my phone. I have a Samsung galaxy note 2. SMS/calls working perfect, how can I get it sorted?
How did you configure your settings?
Did you try the online configurator?
http://48months.tweakker.com/choose/Samsung
Or the Tweakker APN app?
What are your settings right now?
Post them here for review if possible.
I presume that you have a data allowance as part of your membership or data add-on?
The tweakker app helped, thank you
Great - thanks for posting back to confirm that you got up and running using it.
