18-11-2013 06:44 PM
18-11-2013 07:11 PM
Hi There!
Is the Huawei U8815 you posted from the new handset requiring the setting's...?
If so, I know of other's on the forum who had no success with the Tweakker etc when installing Inernet setting's on that handset... I'm fairly sure they had luck with manually logging the Generic setting's though.
Try This Below:
To set up your internet and mms settings:
MMS Proxy: 10.1.11.19
MMS port: 8080
MCC: 272
MNC: 11
Authentication type: PAP
APN type: internet + mms
Let us know if you have any luck or need further assistance.
18-11-2013 07:11 PM
Hi There!
Try This Below:
MMS port: 8080
MCC: 272
MNC: 11
30-11-2013 08:18 PM
Would you be able to give me all that info for the Samsung Galaxy s3 mini GT-I8190N.
I just purchased the Guido package today and the 3G doesnt seem to be working so it'd be great if you could help
Thanks
30-11-2013 10:05 PM
07-12-2013 07:50 PM
my.internet.diden.work.at.all.can.you.help.thank.you
07-12-2013 09:29 PM
08-12-2013 03:41 PM
08-12-2013 03:54 PM
