Internet connection
Hi can anyone tel me if 48 supports d Internet settings for d Motorola moto E? ? I've already bought a fone dey don't support so don't wan a get another if dey don't support it either. Help pls😊
marionh
Crew (retired)
Crew (retired)
The Alcatel phone not working sounds strange though - if it was a really old WAP phone then it might be difficult to configure, but the 48 agents could have got it working if they had taken a look. If it was so old that it didn't have internet access then obviously that would not work then for mobile data.
But yes, Motorola Moto E should work fine though with general Android settings. 🙂
10 REPLIES 10
marionh
Crew (retired)
Crew (retired)
If the phone is unlocked for all networks it should work on 48 as well. Which phone was it that you could not get internet settings to work with 48 earlier?
It was an alcatel flip phone I checked d settings it said 48 didn't currently support d setting for tat phone.
marionh
Crew (retired)
Crew (retired)
Tats great thanks Yes d alcatel fone was only 2g wit was access to d Internet so it prob wasn't a very up to date fone. Thanks for ur help😊
marionh
Crew (retired)
Crew (retired)
Ah right, that might explain it then.
Enjoy your new phone. 🙂
laurarichardson
Hi can anyone help I've moto e 3 months net always worked I bought roaming to go away I couldn't get network coverage in Spain so lost out on my roaming I purchased. I tried everything. I Used viber when wifi was free since came home my internet won't work while everything else does please help saying offline error code err_internet_disconnecteFollowing some auld fella round, u wanna c how handy his job is, he must whistle to work, it's hilarious , he cud b finished by half 9 if he wanted.
laurarichardson
Sorry don't mind end of message someone's message pasted in
laurarichardson
Hi can anyone help I've moto e 3 months net always worked I bought roaming to go away I couldn't get network coverage in Spain so lost out on my roaming I purchased. I tried everything. I Used viber when wifi was free since came home my internet won't work while everything else does please help saying offline error code err_internet_disconnected
