Internet add ons and membership
What happens if your membership runs out after you have bought an internet add on? Will I still be able to use the remaining data on the add on or will I have to renew my membership first?
Hi rory166745
In short... an active membership is required to utilize the service. So No- your Internet will not work...you would need to purchase another membership.
6 REPLIES 6
Hi rory166745
But if I get my membership then will the extra data carry over?
An add-on lasts a month from the date that it is bought on.
A membership last a month from the date that it is bought on.
If the dates are not the same then there will be a period during which the add-on data allowance is combined with the membership data allowance.
However neither add-on nor membership allowances carry over beyond the applicable monthly validity period.
Yeah thanks 🙂
Hi,
I have another question on this: I just bought an internet add-on and my new Membership will start on 21st, so I suppose part of the add-on will be left; so I will have, as an example, half a giga by my add on and one by my membership, will the system use before my add-on or the membership?
The add-on will last a month from the date of purchase.
It may also be extended until 21st August depending on when you buy the new membership. See here but I still don't fully understand the change:
http://community.48months.ie/t5/Techie-Updates/Our-website-is-evolving/m-p/26975#M2112
I think when you have an internet add-on and a membership data allowance then the add-on gets used first but I'm not sure. You might want to clarify with 48 support and maybe post back here with what they say?
