Internet Settings
atray
I've a Nokia Lumia 930 Windows 8.1 phone. I've changes my internet settings, which seem to be working fine but mms messaging isn't. Any help would be appreciated
16 REPLIES 16
What are your settings?
Do they tally with these?
Windows 8 phones
If not then post what your settings are right now.
Remember that to SEND MMS messages you need cash credit - 30c per outgoing MMS.
Hi, thanks for the reply!
I have all the setting the exact same as those above and i've got credit in the account too.
Still not working.
Same as what exactly?
Maybe post your settings here to clarify?
Hi again,
These are my settings:
  • APN  48months.liffeytelecom.com
  • username: leave blank
  • Password leave blank
  • WAP Gateway (URL) / Proxy server10.1.11.19
  • WAP Gateway port / Proxy port: leave blank
  • MMSC: http://mmc1/servlets/mms:8080
  • MMSC Port: 8080
  • Maximum MMS size: leave blank
  • IP type: IPv4
    I have the highest connection speed set to 3G and the automatic APN in unchecked
    Still no MMS
    Thanks
I'm in the same situation with a Nokia Lumia 930, I have my settings all the same and picture messaging is still not working. Please let me know if you figure out how to fix the problem.
Does the online configurator not work?
http://48months.tweakker.com/choose/Nokia/Lumia%20930
Nope, the install guides don't match up when searching thru my phone.
Thanks
adamf9374
Ive an iphone 4 and i cannot get my internet to work. please help
Try the online configurator mentioned above.
Choose Apple and then iPhone 4.
If that doesn't work then you'll have to configure your settings manually using the Internet Settings thread.
Remember to enable data roaming.
If it still doesn't work then post your settings here for comment/review.
