I'm in Germany andy phone just keep searching for a network even though I have mbership etc
My internet works but not the phone, I havd membership And roaming add ons etc but it just keeps searching please help
Probably the same old iPhone problem that lots of other people seem to have had when roaming abroad.
iPhones may need activaton on a new network.
Make sure that you have some credit (at least 25c) and a wifi connection.
If that doesn't allow it to activate then a sync with iTunes may be needed but that's impractical for many people when abroad.
iPhones seem like a lot of hassle in situations like this unfortunately.
And now the adds for the Internet roaming I purchased doesn't work either, even the carrier in the settings of the iPhone doesn't come up. This is a joke , someone please help, thank you for the previous response I will try
I just added €1 to try and it hasn't solved the problem. It says searching and sometimes just no network, so I have Internet roaming nor phone reception on any network . There's always problems with 48
*NO internet roaming
48 don't support data roaming abroad.
You can only use wifi when available.
So the internet add-on is no use to you while abroad.
If you still can't get the phone working on a local network then you probably need to log a support request to ask 48 support for advice/assistance.
Unfortunately iPhones seem to be hassle in situations like this.
Never had the same problems with android.
