28-06-2025
12:05 PM
- last edited on
28-06-2025
12:21 PM
by
28-06-2025 12:20 PM
Original text:
> Cu sa conectez Roming
Google translate (from Spanish):
> How to connect Roaming
What country are you in?
What have you tried?
Is anything working?
Connection to local network/signal bars, calls, texts, mobile data?
