Hi, I ordered a replacement sim and tried to log in to put in new code to register the replacement sim, but there was an error. I was wondering can this be resolved.
Thanks
What error?
Did you follow this guide?
Need to swap your SIM?
If you are still stuck then you may need to contact 48 support for advice:
What error?
