Does 48 have 3 OR 4G?!
mcj1011
MY 48  is 2G. really getting problems downloading stuffs. how can i have a 3 OR 4G SIM CARD or micro sim?! cos there is no option on the web page?!
48 don't support 4G.
But you should be getting 3G (e.g. HSDPA/HSPA etc. or at least EDGE) speeds.
You don't need any special/new SIM card.
How did you configure your internet/APN settings?
What are they?
If necessary contact 48 support for advice:
What are they?
