Defer Calls?
My phone was stolen and I know I need to replace the sim, but is there any way to defer any incoming calls to another number in the meantime?
Shouldn't you order a replacement SIM so that your current one is disabled and whoever took it doesn't use up your calls or make a nuisance of themselves on your account?!
Whatever about that I don't think that there's any way to divert calls without access to the phone/SIM e.g.:
How do I use my Voicemail?
Edit: sorry - I was wrong and it looks like you CAN configure voicemail/diverts from another phone so maybe you can follow the guide above to get your calls diverted as needed if you are not going to order a replacement SIM and disable the current/stolen one...?
any luck with this sassa?
