Croatia joins the EU on July 1st. Does that mean I will be able to us my 48 roaming over there .
Will the 48 roaming network be Available in Croatia when I go on holidays, as Croatia will be an EU country from July 1st. My roaming calls would not work from there last year.
Should work now according to Denise here:
http://community.48months.ie/t5/The-Newsroom/Cheaper-roaming-rates/m-p/3554#M21
You might want to log a support request to ask 48 about this directly in case they don't post back here.
I echoed your query here in case it helps:
http://community.48months.ie/t5/The-Newsroom/Cheaper-roaming-rates/m-p/3516#M20
