Coverage in NI
t5_sk
Will I still have coverage whilst travelling thro Northern Ireland or do I need an add on for roaming?
Assuming that you will not always be close enough to the border to pick up the 26 counties O2/48 networks....
In NI you will be roaming abroad. In which case you will need cash credit or EU roaming add-ons to cover incoming and outgoing calls and outgoing texts.
Other call charges
You will not have data access while roaming in NI.
Other call charges
