01-07-2013 09:37 AM
Hi I am having trouble getting my mobile internet working I am using a Samsung GT-3350 its settings are similar to the Samsung GT-3550 in the help section so tried it and no luck, I also received a configuration message from 48 for mobile internet and one of the options in the message is to install it so when I clicked it it asked for a pin so I put in the pin on my simcard and no luck either any idea what this pin might be? I don't want to put it in wrong too many times and block it?
01-07-2013 09:05 PM - edited 03-07-2013 09:35 PM
I can't understand why it's asking you for a pin as it shouldn't. You could try putting in " 0000 " and see? Or else you can try and use Tweakker APN which may help?
(of course you will need wifi to get this if mobile internet isn't working.)
01-07-2013 09:18 PM
I wouldn't bank on the SMS (if any) sent by 48 configuring the phone in any case. It has never worked for me on at least foud phones that I have used on the network. I have had much better results manually configuring the settings (using one of the listed phones as a guide if necessary) or using Tweakker APN.
06-01-2016 02:08 PM
I had to enter 1234 hope that helps someone
28-12-2017 08:01 PM
Thank you that worked for me 😁
28-12-2017 09:03 PM
Glad it helped.
06-01-2016 02:30 PM
