Can't receive calls
hammo70
Non 48 month phones cannot call me - says number disconnected. I can call , text and have internet & can receive calls from 48 month mobiles
Did you port your number from another operator recently?
I'd so when?
It's possible that other operators haven't yet updated their number databases/routing tables properly yet.
Maybe contact 48 support and ask them to look into it?
I'd so when?
hammo70
Thanks dalyer - I will try 48 support
Did this work for you hammo70? I have contacted 48 support before about this but still can't receive calls from certain 3 and Vodafone numbers
