Android 3g not working
My cubot x16 Chinese android phones won't work.
How can I fix this situation.
8 REPLIES 8
My 3g isn't working on my divice
You need to configure your internet/APN settings.
Follow the instructions here:
If you still can't get it working then post your settings here (screenshots ideally if possible) for review/comment.
To be quite honest that is way too texie for me
What specifically do you not understand in the instructions?
If you want data access to work you simply must configure your settings.
Yes I understand that but where to I find them on her, or my phone? I have a Chinese android called a ( Cubot x16)
You find them in the link that I posted above!
Did you get this sorted?
