48 3G abroad
kasey
Will the 15G of Internet work in Wales on my holiday??? Or would it be a waste buying some ?
No - it won't work.
48 don't support data while roaming abroad so you are restricted to wifi where available.
I presume that that answered your question?
kasey
Sugar.. The place I'm going will have no wifi, so I was hoping it would work, thanks for your time !
Unfortunately not. Man Sad
If you're dependent on data then perhaps you could get a cheap SIM locally and use that?
Of course it wouldn't use your normal Irish mobile number that you use on 48.
