3G
kyleoconnor02
If u run out of data can u top up just the data instead of waiting till the end of da month
Yes - if you use up your membership data allowance before the membership month has expired then you can buy a data add-on which will last at least a month from the date of purchase and, in many cases, until the end of the next membership (unless used up before then):
