3G not working
annie140
Nowhere is offering me 3G anymore only E? Why is this when it used to work
Try deleting your APN/internet settings and reconfiguring them from scratch.
Read and follow these instructions carefully
http://community.48months.ie/t5/The-Knowledgebase/My-Internet-is-not-working/ta-p/45928
If that doesn't help then you might want to try a replacement SIM.
You may also want to contact 48 support for more advice.
