"NaN GB left" - will UK roaming work for imminent trip?
skinthegoat
Currently on 'Guido' membership in Ireland and will be spending a few days in UK shortly.  Will I be able to use 'phone for calls and data there?  My account says that I have "NaN GB left" and I'd like to know just what this means.
Where does it say that?
On the app or on the website view of your My48 account - or both?
That sounds like a bug with the website and/or app.
"NaN" means "not a number" and can happen when a computer calcluates something that doesn't make numeric sense.
You should contact 48 support about it.
Roaming should just work but it seems that some people still have problems so you should heed the usual advice...
