3 hours ago - last edited 18m ago by dalyer
hi need to buy plan. I enter my card details and a grey notification comes up saying that there was an error, try back again later. I have tried numerous times.advice please
18m ago
When were you last able to successfully buy a membership plan?
If this problem occurs when using the app then try the web interface instead (or vice versa) in case that makes any difference.
This is the web interface link:
If neither approach works and the error keeps happening then you'll have to contact 48 support for further assistance.
