Roaming issues!
debbie18
Hello, I am currently abroad and can not access Roaming on my phone. can i add data to get it sent up from my credit ??
What country are you in?
Is anything working?
Connection to a local network - i.e. signal bars, incoming/outgoing calls, incoming/outgoing texts, mobile data?
Any error messages?
