3 hours ago
2 hours ago
If auto-renewal failed because of insufficient funds then you need to buy your next membership plan manually.
Auto-renewal doesn't retry in such circumstances.
After you buy this plan manually auto-renewal will take over again from the following month.
2 hours ago
BTW I think that for the €9.99 plan for 6 months offer to work then auto-renewal has to be enabled and funded.
I think that if you ever disable it or it falls then you might lose eligibility to that offer and you may have to pay the full €12.99 p.m. thereafter.
You may need to contact 48 support to clarify this.
