5 hours ago
3 hours ago
Are you sure that the second plan isn't stacked on your account to kick in when the current one ends?
If it is it will be listed here:
If you still think that you need a refund then you'll have to contact 48 support directly as they don't generally monitor or respond to posts here on the Community Forum.
To contact them see the links in my signature below.
