No calls/texts/data when roaming in UK
ChristinaF7062
Ive enabled roaming on the phone, but the SIM toolkit wont let me click into the when abroad menu item (or. Any of the other menu items). Is there a way to redownload the SIM toolkit or is there another way to make roaming work for me?
The SIM Toolkit is embedded in the SIM so cannot be downloaded separately.
If these threads don't help:
then you'll probably need to contact 48 support.
