My plan is active but it tells me I do not have enough credi
SadieT6420
Your post was blank @SadieT6420 and the subject line seems to be truncated and doesn't really contain enough information to properly explain your issue.
If you want assistance from the Community Forum then you need to explain your issue clearly and in detail.
Do you have an active plan listed on your My48 account dashboard?
Where and when are you being told that you don't have enough credit?
What exactly are you trying to do when this happens?
When was everything working ok for you last?
What exactly is/isn't working now?
Incoming/outgoing calls?
Incoming/outgoing texts?
Mobile data?
What happens when any outgoing services fail?
Any error messages?
