How long will an unactivated replacement SIM remain viable?
TonyM2167
Hey Legend
While reading through other posts, i notice that another customer found themselves in the situation whereby they lost connectivity (reason is irrelevant), and your advice was to have another SIM (replacement SIM) in hand if the situation arose again. Thereby maintaining connectivity.
This is logical, so without having any issues myself with my SIM, i've ordered a replacement SIM (future proofing). My question is, how long will the replacement SIM remain operational without activation?.
If i put the SIM in a draw for 6months lets say (as of yet, auto renewal in place) then an issue occurs, will i be able to activate the SIM 3,6,9 months later. How long does the SIM remain viable without activation.
thank you in advance
tony
Thank you Legend, i'll keep that under lock and key.
tony
12 REPLIES 12
> The phone no. you direct to is for 'complaints and disputes, i'm doing neither.
Others have used that number to contact support.
> customer care's no. is on your invoice.
There's no customer care number on my invoices.
The only phone number on my invoices is my own.
Wow, now it has been deleted. I was wondering while typing reply, why a red banner appeared saying, that your post, doesn't basically exist.
MiracleV9914
My has been wake
