Going to America what's d best membership to cover me while
clairemc
11 REPLIES 11
It's all the same which you use.
With all memberships you'll have to have cash credit to cover the costs of outgoing and incoming calls and outgoing texts.
The charges are the same on all memberships.
See here:
Carrier data services will not work at all so you'll have to use wifi where available.
Did that help at all @clairemc?
clairemc
Heya ye so I'll just buy my normal €10 membership n maybe €20 credit too and yeah where we staying has wifi as has most places in America is this ok!???
Yes - that should work.
Bear in mind that the charges for outgoing and incoming calls are steep enough so €20 may not last that long.
I'd be more inclined to use something like WhatsApp or Skype on wifi for calls to be honest.
You seem to be using an iPhone in which case you will also need to be aware of this issue due to the stupid way that Apple do things:
iPhone abroad issue
clairemc
Brilliant that's great yeah will defo use wats app or messenger for calls so thanks 😊
Glad it helped.
tommielawler
Failure roaming for maura odiscroll
Your post doesn't make sense - again.
You posted here and it didn't make sense either!
http://community.48months.ie/t5/Joining-48/Whats-App-Latest-on-Voice-Calls/m-p/45479#M757
Please clarify what your question/problem is.
Any update @tommielawler?
