100 GB not enough
IrfanT3517
I like to get more GB when my 100 GB run out. But I can’t get until my 30 day’s finish. Why is that ? I want to pay and get more GB but it’s impossible. Any solution?
If you use up your membership bundled data allowance before the membership month is up then you can buy a data add-on allowing you to continue using data for the remainder of the membership month:
If you are regularly using up your 100GB data allowance then maybe you should consider switching to the €12.99/200GB data membership?
