Can I use same number for eir and 48 SIMs?
RichardG0731
Hi,
Just got my 48 SIM.
Can I use the same phone number for my 2 Sims (Eir + 48)?
No. Each SIM must have a unique phone number.
If you want to port your number from eir to 48 then follow the instructions here:
Or, if you want to leave the number with eir then you can use the new 089 number that you get with your 48 SIM.
patc0979
Hi just joined 48, I would like to change my number
Duplicate post - I replied to your other one here:
patc0979
I have left the o3 network and just registered With 48, can I use the old 03 number instead of the new 48 number on the 48 SIM thanks
I'm not aware of any Irish mobile provider named "o3".
Did you mean Three/3?
If you have a number with another Irish mobile provider then you can port it over to 48 by following the instructions here:
Note that you'll need your old provider's SIM still working in the phone in order to receive the porting security code by text.
