buying first plan is not same price as it was!
Sahilg9432
Sahilg9432
it was 9.99 as advertised and when i am buying the plan now, it says 12.99
, i kept my old number
Are you referring to this offer?
If so then are you sure that you meet all the criteria to qualify for it?
E.g. do you have the auto-renew option enabled on your account as required?
If you are buying a plan manually then I suspect not?
Or are you referring to some other offer?
You need to clarify.
