Using my mobile data
gilbertstown52
Using my mobile data why is it that tesco mobile appears o the top of my screen?
Some phones/software don't always identity the network correctly - especially in the case of virtual networks such as Tesco and 48.
If your data is working ok then just ignore it.
If it bothers you too much then you'll have to check for a software update for your phone that fixes the issue.
