Trouble using data roaming when in Northern Ireland
EmmaC6308
I'm having trouble using data roaming when travelling in Nirthern Ireland. I have followed the instructions carefully, but it never works. Can anyone please help
Do you have a connection to a local network - i.e. signal bars?
Are calls and texts working?
Are your APN settings configured correctly?
On the general issue of roaming, the usual generic advice applies...
