Roaming problems in Spain
JamesGerardG0215
Spain roaming prob
JamesGerardG0215
Spain
Your posts were practically blank @JamesGerardG0215 and you haven't described the precise nature of your problem so all I can do is repeat the usual general roaming advice...
So I found out that I needed to change the setting in "48 SIM menu" in the apps on your phone. Click the app then select "when abroad" then select "Network selection" then "manual " and then "international - roaming profile". My roaming finally worked after doing that. Then when you get home switch it back to "local- home profile". Hope this helps
Yes, that's what this link that I posted explains:
