Problems with roaming data & changing APN settings
MariaS5617
Hi, I am having difficulty, using data mobile, roaming in Spain. I cannot access the internet or whatsapp unless I use wifi. It means I cannot use google maps to get around.
I tried to set up a new APN for 48 Internet and MMS on my phone, however although I chose the option to save it, it disappeared. Samsung galaxy A53. Surely 48 should have set the APN up on the sim automatically . Any advice on what to try next would be appreciated.
Many thanks.
If your SIM predates January 2023 then you may need a replacement:
For mobile data to work you need to ensure that your APN settings are configured correctly.
Text "APN" to 50048 and follow the instructions:
For roaming problems check these two threads:
If the APN settings disappear when trying to save them then that sounds like a phone issue and you'll probably need to contact Samsung support or whoever sold you the phone.
If you still have problems then you'll probably have to contact 48 support for further assistance.
JohnOC3997
The following APN settings worked for me Android roaming Italy 2023 / Menorca 2024 / Portugal 2025 / UK 2024 & 2025.
Make sure that you have enabled data roaming (search settings for your phone) also adjust setting in 48 Sim App - When Abroad - Network Selection - Manual - International Roaming Profile.
In the APN type, make sure to use a comma (not a full stop) between words and also use caps for Liffeytelecom
Name - 48 Internet
APN - 48months.Liffeytelecom.com
Proxy - Not set
Port - Not set
Username - user
Password - Not set
Server - Not set
MMSC - Not Set
MMS proxy - Not set
MMS port - Not set
MCC - 206
MNC - 01
Authentication type - None
APN type - default,mms,supl,hipri,fota,cbs,mcx,xcap
APN protocol - IPv4/IPv6
APN roaming protocol - IPv4/IPv6
APN enable/disable - APN enabled
Bearer - Unspecified
MVNO type - None
MVNO value - Not set
After saving, switch on airplane mode and then switch off after 30 seconds and the internet signal should show, may take a minute.
Best answer. It also worked for me. Thank you very much for your contribution.
