Problems connecting dongle & tablet
AntQ0458
I have my sim in a Huawei E5576 dongle, and connect to it using a Lenovov tablet.
However nearly everyday it take ages for the tablet to connect to the 'WiFi'
Is there a trick to getting everything to connect smoothly everytime?
Cheers
Ant
6 REPLIES 6
Just make sure that your internet settings are configured correctly.
https://community.48.ie/t5/Other-Help/Internet-not-working-on-HUAWEI-ASCEND-g6-u10/m-p/34493#M12560
I am not a 48 employee - if you need to contact 48 support then please click here - if the Chat Now option does not appear on that page then keep trying until it does.
How do I change the settings on the dongle?
On the tablet I cannot change the APN settings - because I am connecting via WiFi
You'll need to check the documentation for your dongle.
Normally there's a web interface to configure these things.
This might help but use 48 settings and not 3 settings
https://community.three.ie/t5/Phone-Support-KB/HUAWEI-E5573-Wifi-Router/ta-p/755979#setup
GerOB5390
Is it possible to use a "48" data sim in a router locked to "Three"
No. The device needs to be unlocked for use on any network before it can be used on 48.
