Need help with internet access after buying my plan
ChristopherO3491
Please I need help with Internet access after buying my plan
When did mobile data work ok for you last?
Are your APN settings configured correctly for mobile data to work?
If you're on Android then you can text "APN" to 50048 and follow the instructions here to configure your settings:
