My mobile data is not working - please help
I'm using 48 mobile, my mobile data is not working
Did you configure your APN settings?
Text "APN" to 50048 and follow the instructions:
You'll also need an active membership plan and a non-zero data balance.
If your APN settings are already configured properly, you have an active membership plan and a non-zero data balance but your mobile data still isn't working then you'll probably need to contact 48 support.
See the link in my signature below or email them at support@48months.zendesk.com
Duplicate posts/threads merged - no need to post multiple times about the same issue.
