APN not working Nexus 4 Android 6.0
niall8100
I recently updated my Nexus 4 phone to Android 6.0 myself and have tried to set up my mobile internet again. However no matter what configuration of the settings I try(eg. APN Type: default,mms,supl or just*) nothing seems to work. Below are my APN settings, anybody have any suggestions?
Do you definitely have data AND data roaming enabled?
11 REPLIES 11
No problem.
I should have mentioned it earlier but didn't think.
Your original settings should work fine just in case you changed them since.
Glad you got it working. 🙂
Yeah I was so confused why it wasn't working, was wrecking my head for the last day and a half 😛 Thanks again!
