@techie_kev wrote:
@dalyer - are you still using a Huawei G300? You mentioned that handset in a previous thread, so just wanted to double-check.
No - I'm using a Haier W910 running Android JB 4.1.2:
http://www.chinaphonereview.com/haier-w910
I have not had problems with loss of data until recently.
@dersonly1shano wrote:
Hi my 3G has not worked for weeks... Tried a network reset and it works for about 3 hours...calls also been affected
Hey,
If calls also affected then it sounds like your issue is not limited to the 3G problem, so it's best if you contact an Agent about it so they can investigate the broader issue - pop a new request here.
My issue is slightly different, I'm not too sure if it related. I bought extra internet as an add-on but my internet doesn't seem to be working. Is there an activation period?
Hi 1amcn,
Yes I do. It expires next month. My calls and texts are still working fine. Do you know if I have to wait a certain amount of time before my internet is operational?
Unfortuantely the online account does not clarify when an internet add-on expires.
It's a bit of a flaw that I reported to 48 support a while back.
Dialing *100*8# may tell you when it expires - I can't remember.
However if you have bought an internet add-on and have a current membership then it should work.
You do also have to configure your internet settings for it to work though - follow all of the steps here to do this:
Thank you for your help!
DId it work?
What did you do?
I have an iPhone and I followed the instructions below!
Username - leave blank
Password - leave blank
MMS Proxy - 10.1.11.19:8080
MMS Max Message Size - 307200
MMSC UA Prof URL: leave blank
Thanks again
OK - so the issue was that you had an internet add-on but had not configured your internet settings but now that you have it all works fine? That's good.
