[Resolved - March 2014] Issue with losing 3G connection
techie_kev
Crew
Crew
**This issue is now resolved, please see the final update below**
Hi everyone,
We are currently experiencing an intermittent issue where some handsets appear to be losing their data service.  This is affecting a small number of customers and some of you have already raised queries about it here on the Community.
To fix this issue, please just ‘power-cycle’ your phone (turn it off, wait a few seconds and turn it on again).  This may seem like the usual solution to many technical problems like this, but it serves to completely disconnect your phone from the network and it should then re-establish itself on the network again with a working connection.
We are working hard to get to the bottom of the issue.  Unfortunately due to the intermittent nature of the issue it is difficult to pinpoint the root cause but we are confident our engineers will get to the bottom of it shortly.
If you are continuing to have issues with your data, please double-check your data settings first to ensure that your phone is still storing the correct settings.
Techie Kev
Final update: Wednesday 19th March at 18:00
This issue is now being marked as resolved. As I mentioned before, a fix was put in place by the other operator to stop sending the disconnect data message to our handsets. In the last two weeks we have done extensive testing and we have not seen the issue re-occur. The other operator has also tested this and has seen the same positive results.
We know this issue, in particular the amount of time it took to resolve, was extremely frustrating for you all. It isn’t something we have taken lightly. The fact the cause was outside our own network and core systems meant it took longer to pinpoint the issue.
Providing you with a reliable internet service is a key priority for us. We have invested considerably in improving your internet speeds and reliability over the past 12 months.   With this issue now resolved, we hope you will now be able to continue to enjoy fast and reliable data speeds on 48.
If you do have an issue using your internet then it will be related to another issue. Please check your internet settings first, if these are correct then please ask a 48 agent who can look into this for you.
Previous updates:
(click on "more info")
More Info
Fri 7th March at 16:35
We are confident that this issue is now resolved.  A fix has been put in place by the other operator so that they are no longer sending the disconnect data message to our handsets.  This fix has undergone extensive testing by them to ensure it works correctly for both our customers and their own. We have also completed extensive testing today and we have not seen the issue occur again.
We will continue to monitor this closely over the coming days until we are sure this is fixed before we close this issue as resolved.
Tues 4th March @ 16:52
We are confident that we have finally got to the bottom of what is causing this issue. We have discovered that another network is sending a message to our customer’s handsets to stop it from using data.
This happens when a 48 phone loses coverage and then attempts to reconnect to the network. If the other network’s signal is stronger it picks this up first. This request should simply be rejected until the phone re-connects to 48, however in this case a message is being sent to the phone to tell it to disconnect from all data, even when 48 is picked up again.
A solution is being tested by the other network and we should have more information in the coming days. We really appreciate your patience with this issue. It has been a really complicated issue to get to the bottom of, particularly as this is another network affecting our customer’s handsets. All resources will continue to work on this until it is resolved.
Please remember, if you do lose your data connection, please just ‘power-cycle’ your phone (turn it off, wait a few seconds and turn it on again) to restore the connection.
Tues 18th Feb @ 12:00
Following a number of different changes we have implemented on our systems, we are seeing a noticeable decrease in the number of customers reporting this particular issue.  We are now closely monitoring this to see if the issue has been resolved for everyone.
You can lose your data for a number of reasons (handset issue, congestion at peak times, local signal issue, etc).  The storms over the past week have also caused disruption to signals across the country, which could also have affected your data connection. So, it can be difficult to pinpoint if a customer losing their data is related to this particular issue.
A key symptom of this issue is the E, 3G or H symbol disappearing from your phone, but you still have a signal (the signal bars) and calls/texts are working fine, it is just your data that is not working.  A restart of your phone resolves the issue and the data symbol returns to your phone.
If you are still experiencing this exact issue and the 'phone restart' fix has worked for you we really want to hear about it from you.  There are some details that would be very useful for us to have, so if you could also let us know:
  • Type of phone
  • What services (calls, text or data) or apps you were using at the time
  • General area you were in when it happened
  • Has the issue happened just once or more often?
  • Did your data symbol (E, 3G, H, H+, etc) disappear while you had no data?
  • Did calls and texts work while you had no data?
  • What data symbol did you see before lost data (E, 3G, H, H+, etc)
  • When did you notice you lost data?
  • Were you on the move when it happened?
4th February @ 15:43
We are still actively working on resolving this issue. We made a number of further updates to our systems overnight as part of this work. We are monitoring all our systems closely today to determine if these changes have fixed the issue. In the event these changes haven’t been successful it will help us narrow the focus to other potential reasons for customers losing their data connection.
Please let us know here on this Community post if you have lost 3G internet connection again today (after 6am on Tuesday 4th February).  Also, please let us know if you have been repeatedly losing your 3G connection and it now appears to be stable again.  Your updates here will help us determine the success of these changes.
Remember, a ‘power-cycle’ of your phone will resolve the issue if it happens to you.
Tues 28th Jan @ 17:10
Just a quick update on the investigations into this issue. Due to the ongoing nature of it a dedicated investigation team from a number of our service providers will be working on it until the issue is resolved. A number of further tests are planned overnight and tomorrow morning to get to the root cause. I will continue to provide updates here on the progress of these tests.
Please remember, if you do lose your data connection, power-cycling (turn off and on again) your phone will restore the connection
148 REPLIES 148
looney
I lost my internet today at about 11 am and it hasn't worked since have full interet  left and reset network settings and done a power cycle .....and its still not working!
imeldab
This has started happening me from this morning. I've only had 3G work once for about five minutes. Turning off the phone doesn't help. I even restored my entire phone to see if that would help. No luck.
goodtwin123
No internet all day. Tried resetting phone and turning on & off. Whats happening?
Hi all
I would suggest, (as well as posting here)- to log a 48 support request also.
Be as descriptive as possible, and include where you are (town & county) make and model of handset, & when you lost 3G (time, approx)
I would defer from any other troubleshooting method, save from either a power cycle/flight mode toggle, as suggested by 48 themselves.
codob123
I had perfect connection up to last night, this morning on my way to work i noticed i couldnt load any pages, After restarting the phone i get intermittent connection. I kept trying to do a speed test, It succeeded around once out of 20 tries fully. other times it starts, and half way through the test gives me a network communication error. When it succeeded i got around .2 down, where i live being so close to a mast i usually get 3.5odd. Also sometimes when browsing the net the loading of pages times out, or sometimes i get redirected to an "error 53" page saying temporary service issue. I dont know if this is a message from the chrome browser on my phone or if it is from the 48 network.
Anyway just said id let you know what has been going on for me, as i said working perfectly until this morning, and even after restarts its intermittent, and very slow. Maybe its just me i dont know. Sure let me know if its just me, otherwise said id try help.
Are you sure it's not http error 503 - service unavailable because the data connection disappears while the browser is trying to do something?
http://en.m.wikipedia.org/wiki/List_of_HTTP_status_codes
Your right, Just tried to load google there. First time got the little chrome dinosaur icon. No connection.
Refreshed and i got just text but the layout was wrong and got no images,
Third try i got the following, loading each page took ~20 seconds which for a HTC One is longer than usual given i can see a mast outside my window.
undefined
I have an iPhone 5 and I do not have data connection neither. Tried to turn my mobile off and on again but it doesn't help.
Hi i have lost my internet connection since like the 3rd on feb.. can it be fixed pls!!
Woke up this morning and my internet is working fine again!
