second plan on the same account
i am try to add a second plan but every time i click buy plan it brings me here
You already have two upcoming plans stacked on your account.
One to start on 2nd September and the other to start on 2nd October.
And you have auto-renewal enabled anyway so you shouldn't need to buy plans manually.
But, if you really want to add a third then click Show More and you should be able to buy another one.
Or try this link:
