receiving picture mms
siobhron
I've tried to check the data settings for my new Samsung J3 to find out that 48months do not support configuration of my samsung phone. I can't send or receive mms, I do have internet. Has anybody any update on this problem?
MMS are charged at 30c Per Message, have you tried adding credit and attempting to send one?
Your interent is working so that means you have had sucessfull Internet configuration.
On the flip side, some handsets just do not support MMS settings, like my own (Nexus 5)
Internet can work even if the MMS settings are not correct.
Follow the instructions here to make sure that your APN is configured for internet access AND MMS send/receive.
What do you mean by the Nexus 5 not supporting MMS settings?
I find that difficult to understand.
Seems to me that it should work - e.g.:
https://productforums.google.com/forum/#!topic/nexus/VW_L9kVVy8g
