When I try to top my plan up it said oops something went wri
Rianm5159
Your post was blank @Rianm5159 and the truncated subject line doesn't really give much to go on.
If you want assistance from the Community Forum then you need to explain/describe your issue clearly and in detail.
What is the exact verbatim error message that you're getting?
When were you last able to successfully buy stuff on 48?
Is your payment card still valid, not frozen via your online banking, and there are sufficient funds in the account if it's a debit card?
Are you using the app or the web interface?
Does it make any difference if you use the app instead of the website or vice versa?
If you need to contact 48 support about this then see the links in my signature below
