Sharp Z2 smart phone
jbt
hi,
I have just bought a new Sharp Z2 from China and it will not connect to the 48 network although it identifies 48 network as a choice of three networks to connect to. I have changed the sim to a nano sim and activated it on line but activation is still in "pending" status. Any one got any suggestions. The phone seems to work otherwise.
John
Did that help at all @jbt?
Sounds like your SIM has not actived.
This normally happens quickly so if there's a delay here you need to contact 48 support and ask them about it.
Thanks, it was a sim activation issue. Its working now, your help is much appreciated.
Great - glad it's all sorted now @jbt.
