Roaming not working in Northern Ireland
GaryR5483
Hello I am from Donegal in the Republic of Ireland but I am currently in the North and I cannot get my roaming to work so I cannot access anything on my phone so how do I turn roaming on
6 REPLIES 6
SenC0074
If on iPhone: Mobile Service > Mobile Data Network > Change APN under Mobile Data to 48months.liffeytelecom.com
Let me know if this works..
Is anything working - e.g. calls and texts but not mobile data?
Check out these threads:
If they don't help then you'll have to contact 48 support for further assistance.
If your SIM predates January 2023 then you might want to get a replacement in case that helps:
maryfeeney
Have the same problem - 48 roaming useless in Northern Ireland and no support from 48. Had this problem last year and again today. Will have to change,
I presume that nothing that I posted here helps you?
My daughter is with 48 and she has had this same issue everytime she is in the North, will try this above next time she's in the North, however from Reading the other threads about possible solutions, that seems like a very manual process to have to go through each time??? U suggested ordering the new sim, do u know if the newer Sims have this fix built in???
If the SIM predates January 2023 then it's no harm to try a replacement.
It may work better when roaming.
However even then I believe that you may still have to do the manual stuff mentioned here each time you go abroad and then return.
